Writing to slave vesc sometimes cause loss of can bus
meashman
Last seen: 2 years 4 days ago
Hi, lately I've been having the issue of reading/writing to the slave sometimes causes the loss of the can bus connection mostly when using the android app via BT and the esc stops responding. If I reboot the esc's it's back again, I'm using v5.3 on flipsky 6.7 esc's. Similar problem happens on dv6 maker-x also, is there something I'm just doing wrong or a known issue?
Tried searching but couldn't find anything about it.
Heddonvamp
bump
This is third party hardware and not VESC. If you loose CAN connection you should contact the manufacturer. Or did you loose BT connection to the phone?
