Custom App - Set Motor Speed
CTSchorsch
Hi all,
i have a custom app, to control the motor for my underwater diving scooter. This scooter has a trigger button for run/stop and a rotary encoder to set power from 10% to 100%
At the moment i control the motor just with mc_interface_set_duty(0..1)
Is this enough ? or do i have to set something more ? maybe current ? all other apps do so much more :)
Georg
#include "app.h"
#include "ch.h" // ChibiOS
#include "hal.h" // ChibiOS HAL
#include "stm32f4xx_conf.h"
#include "mc_interface.h" // Motor control functions
#include "hw.h" // Pin mapping on this hardware
#include "timeout.h" // To reset the timeout
#include "utils.h"
#include "commands.h"
#include <math.h>
#define SPEED_STEP  0.10
#define SPEED_MAX   1.00
#define SPEED_MIN   0.2
#define SPEED_OFF   0.00
//private variables
static volatile bool stop_now = true;
static volatile bool is_running = false;
static float targetSpeed=SPEED_MIN;
//Threads
static THD_FUNCTION(dpv_thread, arg);
static THD_WORKING_AREA(dpv_thread_wa, 2048); // 2kb stack for this thread
static thread_t *dpv_tp;
virtual_timer_t dpv_vt;
//private functions
//void dpv_rotary_isr(void);
static void update(void *p);
void dpv_rotary_isr(void) {
//  commands_printf("Interrupt");
    if ( palReadPad(HW_HALL_ROTARY_B_GPIO, HW_HALL_ROTARY_B_PIN) ) {
        targetSpeed += SPEED_STEP;
        if (targetSpeed > SPEED_MAX) targetSpeed = SPEED_MAX;
    } else {
        targetSpeed -= SPEED_STEP;
        if (targetSpeed < SPEED_MIN) targetSpeed = SPEED_MIN;
//  commands_printf("TargetSpeed: %d",targetSpeed);
void app_custom_configure(app_configuration *conf)
    (void)conf;
void app_custom_stop(void)
        stop_now = true;
        if (is_running) {
        chEvtSignalI(dpv_tp, (eventmask_t) 1);
        mc_interface_release_motor();
        while (is_running) {
                chThdSleepMilliseconds(1);
void app_custom_start(void) {
    EXTI_InitTypeDef   EXTI_InitStructure;
    stop_now = false;
    // Set the UART TX pin as an input with pulldown
    palSetPadMode(HW_HALL_TRIGGER_GPIO, HW_HALL_TRIGGER_PIN, PAL_MODE_INPUT_PULLUP);
    palSetPadMode(HW_HALL_ROTARY_A_GPIO, HW_HALL_ROTARY_A_PIN, PAL_MODE_INPUT_PULLUP);
    palSetPadMode(HW_HALL_ROTARY_B_GPIO, HW_HALL_ROTARY_B_PIN, PAL_MODE_INPUT_PULLUP);
        // Interrupt on HALL ROTARY A Pin
        // Connect EXTI Line to pin
        SYSCFG_EXTILineConfig(HW_HALL_ROTARY_A_EXTI_PORTSRC, HW_HALL_ROTARY_A_EXTI_PINSRC);
        // Configure EXTI Line
        EXTI_InitStructure.EXTI_Line = HW_HALL_ROTARY_A_EXTI_LINE;
        EXTI_InitStructure.EXTI_Mode = EXTI_Mode_Interrupt;
        EXTI_InitStructure.EXTI_Trigger = EXTI_Trigger_Rising;
        EXTI_InitStructure.EXTI_LineCmd = ENABLE;
        EXTI_Init(&EXTI_InitStructure);
        // Enable and set EXTI Line Interrupt to the highest priority
        nvicEnableVector(HW_HALL_ROTARY_A_EXTI_CH,6) ;
    // Start the dv thread
    chThdCreateStatic(dpv_thread_wa, sizeof(dpv_thread_wa), NORMALPRIO, dpv_thread, NULL);
        chSysLock();
        chVTSetI(&dpv_vt, MS2ST(1), update, NULL);
        chSysUnlock();
static void update(void *p) {
        if (!is_running) {
                return;
        chSysLockFromISR();
        chVTSetI(&dpv_vt, MS2ST(2), update, p);
        chSysUnlockFromISR();
static THD_FUNCTION(dpv_thread, arg) {
    (void)arg;
    chRegSetThreadName("APP_DPV");
    dpv_tp = chThdGetSelfX();
    is_running = true;
    for(;;) {
            chEvtWaitAny((eventmask_t) 1);
                if (stop_now) {
                        is_running = false;
                        return;
        const volatile mc_configuration *mcconf = mc_interface_get_configuration();
        float motorSpeed=SPEED_MIN;
        if (app_is_output_disabled() ) {
            continue;
        if ( mc_interface_get_fault() != FAULT_CODE_NONE) {
            continue;
        // Apply ramping
        static systime_t last_time = 0;
        static float motorSpeed_val_ramp = 0.0;
        float ramp_time = fabsf(motorSpeed) > fabsf(motorSpeed_val_ramp) ? 3.0 : 3.0;
       if ( ! palReadPad(HW_HALL_TRIGGER_GPIO, HW_HALL_TRIGGER_PIN)) {
            motorSpeed=targetSpeed;
            if (fabsf(motorSpeed) > 0.01) {
                ramp_time = fminf(3.0, 3.0);
            if (ramp_time > 0.01) {
                const float ramp_step = (float)ST2MS(chVTTimeElapsedSinceX(last_time)) / (ramp_time * 1000.0);
                utils_step_towards(&motorSpeed_val_ramp, motorSpeed, ramp_step);
                last_time = chVTGetSystemTimeX();
                motorSpeed = motorSpeed_val_ramp;
            mc_interface_set_duty(utils_map(motorSpeed, 0, 1.0, 0, mcconf->l_max_duty));
        } else {
            motorSpeed=SPEED_OFF;
            mc_interface_set_duty(0);
        // Reset the timeout
        timeout_reset();
bayetan
Hello Georg,
I think you might also need the following.  This will cause to thread to sleep and return in 5 ms.
      chThdSleepMilliseconds(5);
