Vibrations under hard regen
gecko242
Hi All,
I have a Maker X HI 100 (VESC 6 based), running at 48V connected to a 1KW 26 inch hub motor, with hall effect sensors.
I have run a FOC detection and all looks good.
At regen levels greater than 50A, I get a strange vibration, almost as if the hub motor is desyncing.
I get a similar vibration under acceleration above 70A, but I would imagine this is due to core saturation as I am greatly exceeding the power rating of the motor.
Any suggestions? Thanks!
Could be the case and tracking a saturated stator is not easy. You can watch Vedders Youtube Channel to get some advice on how to change parameters and tweak things a bit.
