75300 r2 v5.3
Oscarmanassan
75300 r2 v5.3
Hola, dónde puedo descargar este firmware antiguo que es el único que me funcionaba?
tobiokanobi
The BETA VESC-Tool features a firmware archive. Go to firmware and open the Archive tab, then load the archive and voila!
Oscarmanassan
Muchas gracias,es la versión 5.3?
Yo
You need the BETA VESC-Tool, Version 4.0! Don't confuse FW version and VESC-Tool version.
You can find the BETA Tool in Purchased Files, top of the page. If it doesn't show up, please check out VESC-Tool again (any version is fine).
ozcankosar
I have the Flipsky 75100 With Aluminum PCB. There was Focbox before, but unfortunately it burned down. What firmware should I install for 75100? I will use it for MIT RACECAR. Has anyone used 75100 on this car before?
Brian123
Brian123's picture
i have a 75100v202 and cant get the damn thing to spin at all. it once went with an old version of vesc tool but since cant get that version no longer , and now on the new versions of vesc tool ive been trying for weeks and wont spin up on motor wizzard and ive tried just about everything twice and cant do it.i had same prob when i first got it on this laptop, no go, then took it to ex house where i ad old laptop with old version of tool and got it working. but now that is not avalable and stuck trying to do this for weeks. i need help , this thing is useless to me
BG
rogerio
Last seen: 8 months 5 days ago
bom dia. Estou enfrentando dificuldades na configuração do vesc 75300 r2. Bom, estou usando vesc tool 6.02 e rádio controle ppm, faço as configurações e ocorre o seguinte, o motor não liga, continuo. gira e para, gira e para, alguém pode me ajudar?
