error firmware BMS
Sebastiangeitne...
error firmware BMS
Hello, from germany.
I need some help. I own a new trampa board with 2x vesc 6 mk VI and the PCB 21700 IiIon battery pack with BMS.
I wanted to try the silent hfi and might have made a mistake when changing the firmware.
Now the regular firmware has been loaded onto both vescs again, but i did not receive live data from the BMS. Both vescs are listed but the BMS is missing under Can Device [BmS (12s7p)]. I hope someone can help me Greetz Sebastian
Sebastiangeitne...
I disassembled everything, left it for two days. This morning I connected the battery pack to the computer, after which it woke up and the green LED bright mouth was flashing rapidly. I was able to flash it successfully via the software.
Magic!
