FSESC75200 stopped work after firmware update
julia borisova
Last seen: 1 year 3 weeks ago
I've bought controller Flipsky FSESC75200 and started configuring it with vesc_tool_3.0. Vesc software detects not latest, but compatible firmware. Motor connected to controller rotates smoothly and silently in Duty Sweep Experiment. Hardware version is VESC_75_300_R3. Then I updated firmware to latest version, motor stopped working properly, it jerks back and forth, but does not rotate continuously.
Could you recommend another firmware versions that I can try?
supertiny808
supertiny808's picture
The Flipsky controllers don't support the latest Firmaware I don't think, you may need to just stick with V3 which is still pretty good
808
