Using vesc for Position and driving my BB8 Robot
Quicksilverstar
Quicksilverstar's picture
Last seen: 8 years 10 months ago
Hi everyone, i come across this esc due to seeing youtube videos explaining position , i am working on a BB8 project and looking for a controller for the head
control, which is using brushless motors this esc would be perfect, i would have to redesign the PCB to have two controllers to save space and the main drive to have a forward and reverse driver
my questions are, i would like to use harmonic drives and encoders, i have  RLS RM08 12bit  encoder with SSi interface which works by bit banning the clock and reading the 12bit of data that is
the position of the magnet and the output is the current magnet position and will always give the  value of where the magnet  even if the power is removed
and returning an integer can this be added to the firmware, also can the encoder be put on the output shaft of the gearbox and not the motor
the other is do any of you already have the already setup code for using the cam bus or SPI slave to set the position and take out anything code that is not really need
VV8....Frank
Quicksilverstar
haha, vv8 seriously no one want to help, i have added a picture   i hope you can see the link. BB-8 Assembly V1.6_2.jpg
Here are the brushless motor that i would like to control
I think you need a reply from Benjamin to get your stuff sorted. I'll point him to your request. Frank
Quicksilverstar
Hi it's ok i have started writing my own firmware as i want to use the stm32F407 UFBGA176  1Mb
I will be controlling two BLDC  motor using DRV8301's from the came chip
as i want to allowing to setup using a OLED Screen
