VESC tool and Flipsky7070 electric motor
Gennady
Hello all!
I am trying to build a remote control dinghy. For example, this short:
https://youtube.com/shorts/v_XYwqSeswA?si=_bxaaeNVfhC93vrd
The motor I am using is Flipsky 7070. I bought the Flipsky75100 Pro, which is a VESC.
I spent two days trying to make it work in both directions, but with little to show. Can someone provide me with needed parameters to make it work with the VESC tool?
1) Specifically, when I do Setup motor FOC, the parameter that came back as 0 (or practically zero) during the FOC motor wizard detection was the Motor Inductance (measured in microhenries.
2) There is no reverse for "Duty cycle", or "Current cycle". I need the motor to work on both directions, as this is a dinghy.
3) When I tried to set up the motor not as FOC, but BLDC, there was no working wizard to help me set it up.
Hence, again: what are the parameters that can make such or similar motor (middle size outrunner) work?
Thank you for you help,
Gennady Kozak
Roog
Last seen: 2 months 5 days ago
Hi @Gennady,
I had a similar issue, a model locomotive which has two Flipsky 7070 and 75100.  I used FOC mode and used the wizard, I found it reletively straight forward with help only required to get the CAN bus link to work between the two VESCs (whhich are quite far apart) to control both motors identically.
Your enpass is very difficult to diagnose from a far.
My recommendation, try the FOC wizard.
I wish you good luck.
