Flipsky 75100 V2 with Maxon 386675
GoFast99
Hello All,
I'm having some issues with excess heat in the maxon motor https://www.maxongroup.com/medias/sys_master/root/8825423560734/17-EN-215.pdf  when running the Flipsky ESC https://flipsky.net/collections/v75-series/products/75100-v2-0-with-aluminum-pcb when powered by a meanwell 48v power supply.  I'm attempting to use the Flipsky to run the maxxon motor to drive some test fixtures up to 30k rpm, but the motor heat seams to be an issue when even running at zero load at that speed.  Anyone have any pointers for figuring out how to better run these motors at those speeds?
I've tried both BLDC and FOC detection and modes, zero regen, and lowered the maximum current values.    Any ideas?
