Need advices for choosing hardware
ph0en1x4
I'm new in the world of VESC, I'm currently starting my first project.
I have a e-scooter, it's a Dualtron Thunder 2 and it had burned battery. I got it like it, I cleaned and painted parts I could save, and buy new other parts. Frame and motors are fine.
So I'm making a new battery with 8p20s Samsung 21700 35A 5000mAh, BMS will be able to deliver 230A constant and 525A peak. Battery can do (8x35) 280A, but I'll limit it to 200A first.
The original controllers were 2x60A peak.
I'd like to use 2x100A controllers VESC, but I'm a bit lost of what I can get.
First I found that the Flipsky 75100 can handle it, and also the MKS 75100.
I also find the MKS 84100 is 100A constant, what it different from 75100 ?
I finally found that Spintend also makes some VESC controllers... I'm lost, I don't know what to choose.
What is better for my configuration ?
I'll have the 2 original motors (without hall sensor), a display (Flipsky display) and a twist throttle.
Thanks for your advices.
