Help using Vesc tool using 2 Flipsky 75100 pro V2 on one Motor ?
Marc Fortune
Last seen: 1 month 4 days ago
Hi, new here so I apologize if I selected the wrong forum topic, correct me if I'm wrong.
So I have a 3000w Hub motor thats on a Motorbike/scooter, stock the have whats described as a " duel mode Motor" it comes with two standard controllers that run the 6 Phase wires and teh hall sensors are split providing the same info to both controllers. It runs fine with one controller on either set of phase wires but to unlock the 227lbs or torque I need two running.
Having setup the fipskys individually with Motor setup and input, both controllers work great on their own, when both are on together the issue I get is initial off the line hesitation, I assume the Phases arguing whose going 1st, but after 5 seconds its off like a rocket, and my smile appears.
My question is weather its possible to detect the 6 phases with vesc at the same time rather than setup the controllers independently, the initial hesitation is an issue especially at traffic lights or pulling out, the delay can be dangerous.
Any help would be much appreciated
marc
