Flipsky 75200 struggle/cogging on higher voltage >>> Solution
Strippenstrolch321
Last seen: 2 weeks 2 days ago
what happend?
The gates of the 7769 Mosfets are driven too hard / Gate resistors too small (maybe just a design issue (hard switching = distortion)
On prevous 75200 (until 2021) the six Gate Resistors are 1.6 ohm ( SMD 0603)
Later they change them to 4.7 ohm .
BUT ,
if the input voltage is higher than 30V there are massive Problems with cogging / stuttering / Motor screaming.
When the voltage gets over 45V it ist just unusable.
SOLUTION:
Change the six Gate resistors to 16 - 22 ohm (all of them must be the same )
Change the Dead time in the Firmware (16ohm ~ 1450ns) (22ohm ~ 1650ns)
(this point is tricky ----better check with Oscilloscope )
At least change the switching frequency to 13 - 16 KHZ to reduce switching losses
Test @ 185A with Flipsky 80100 Motor on 16S ....worked like a charm
Disadvantages of this solution :
Lower efficiency ,much more heat on the 75200, some noise from the lower frequency
Strippenstrolch321
After hours of testing found a new sweet spot.
R gate 15Ohm
Deadtime 1300ns
FOC frequency 20khz (switch to 30khz while motor measurement (FOC Wizard))
at this point its getting less hot and is nearly qiet.
