Issues flashing VESC HW 4.12
Nic_cfar
Yesterday, I was working with a VESC HW rev 4.12, it's basically the original VESC hardware aside from some minor modifications to I/O, when suddenly VESC Tool did not recognize that a VESC was plugged in; nor did my computer recognize that the USB port was plugged in. The VESC was running FW 5.1 and had been working the day prior: able to connect via USB with USB power. Since VESC Tool did not recognize the VESC, I thought it may have been possible I killed it with ESD while working on it; although a possibility I was working on a ESD mat to help mitigate this. I have no way to know if that's the case though, so I started to try and reflash the bootloader. I plugged in my STM32 ST-link via SWD and attempted to reflash; however, ST-link utility said that the STM32F4 was in read protection mode level 1 and cannot be erased and as such I cannot change the content of the flash. I also tried uploading a program via STM32cudeIDLE; however it would also fail. Both programs were unable to detect the flash size which is another reason I think it's dead.
The more I speak about this, the more I think I should ask the STM forums as I think the chip is not working. I know that pin BOOT0 is tied to ground so it's hard to reset after it's been set to read protection mode level 1.
Thank you for any advice,
Nic
xeniter
had exactly same issue after soldering imu, have no idea how that happenend, strange is that st-link can read out ID, however erasing is not possible anmyore cause read out protection is enabled can i can't disable it, assume stm32 is dead cause of esd or maybe heat, switched now to new board with a new stm32 (board was cheap focer 2)
