Noob....Power profiles on Android vesc tools
tailele
Good morning...now i explain my problem. I have a scooter with two motors. The front motor could be turn on or off with a botton. Now i would have 4 different set ups with 4 different velocites in vesc tools android app. I use a ubox mainboard 75v and 200 amps . I connect the board with bluethoot . When i choose a profile, this set up Is Only use in One motor, instead the second motor works with the standard profile. Is It possible to set the same profiles in the same time? Thanks
