copy setup from one vesc to another?
curtm
I have two brand new Flipsky 6.6 Dual Vescs.  I can connect to one via USB but not either side of the other one.  I bought a ST-Link and can connect to both of them that way.
The one that I can connect to is programmed the way I want the second one.  Is there a way to download the configuration from the one I can connect to via USB (or ST-Link) and upload that configuration to the other one via ST-Link ?
thanks,
Last seen: 2 months 8 hours ago
A better option might be to use canbus or a bluetooth module if you have one.
curtm
I have ordered a Bluetooth module from Flipsky and it’s taking forever to get here. I don’t know what Canbus is.
Curtm
Connect the CANH and Canl pins of the two vescs together, power them both up and connect to the good vesc with over usb. Then go to connection on the left and click can forward and you should be connected to the second vesc.
