Flipsky FSESC 4.12 Bluetooth over mini USB?
blaz.ferlic
Last seen: 2 years 1 week ago
Hi, I just realized I cant use my Bluetooth module with my Flipsky FSESC 4.12 because im using a Flipsky VX2 remote which plugs into the same COMM port. Is there an obvious solution I'm missing?
Is it possible to connect a Bluetooth module over the mini USB port? Some other port or do I have to get another remote?
Any help is much appreciated.
lurch
Last seen: 2 days 23 hours ago
you can use metr at bluetooth module on can bus .
also there is uart splitters , but not recomended ..
or another simple remote with ppm receiver . the uart port will be free..
blaz.ferlic
Thx for the info. The metr looks cool but is a bit expensive. I can just plug in the Bluetooth module when I ned to change some settings right? And than just plug the remote receiver back in.
lurch
yes . but depends if you want realtime data on ride , and make log's to analyse them later..
