Help with noise in rpm and ppm
martin2day
i build myself an VESC. It run but i get some noise in the rpm and ppm signal from my RC Resiver.
I think i do some errors in my layout with GND Routing or Placemant of the Elemnts.
Please can someone have a look at my layout and say whats wrong in the routing and can cause my problems... :-)
Thank you very much
Regards Martin
VESC 12 TO-220 MCU.zip
VESC 12 TO-220 Power.zip
martin2day
here you can see what happen when i switch full brake...
The rpm goes up to 250 rpm...    can i chance this in the setup?
I need some help, please.
Martin
martin2day
me again... i find a solution for me... don't know why.... :-)
I play with all the paramter i can change in the software.
If i lower the Dead Time Compensation (half the original) than i see only half the rpm at brake und 0% DC.
At the end i setup 0,000uS und now i have 0rpm at brake and at 0% dc... and the motor starts everytime fine.
Can someone explain this to me?
Martin
