Motor not spinning NO FAULTS
123seaborder
Hey guys  I changed the drv on 4.12 hw. I get every data in vesc tool. Even when I spin the motor by hand I can see it in rt data exactly. But motor detection ends in bad result and no spin at all. Cant also spin the motor with arrow keys. I get no faults also. Mosfets and gate resistors seem fine. I was thinking about the gnd pad of the drv got not reflown correct but would the vesc even turn on if thats true? I dont want to take it off and on again and check for other issues before. Also updated fw. I really cant find out where the issue is.  Any suggestions?
gogglespast
Sensorless? Do you give it enough amps when you try to start it?
Temple Run 2
