Flipsky Dual 75100 forward, brake, and reverse
Shockwave333
Last seen: 4 months 2 days ago
Im currently building a go-kart using a dual 75100. I have to pedals. One forwards and one brake on adc 1 and 2 respectively.
Im also using adc and uart mode because im using the bluetooth display on my phone as my dash display.
From what ive read I need a switch of some kind to control turning the forward pedal into reverse. What kind of switch and how would i go about wiring it?
voodoobrew
From what I have read you just use a toggle switch to ground and RX for the brake button.
Some posts say on some firmwares the RX pin will not work as a brake button with uart enabled.
I have tried many things but I cant get it to work for the life of me.
I am als trying to build a gokart with one Flipsky 75100 Pro V2.0 and having this issue if anyone has a solution.
