Vesc-Tool_ISW_Twin VESC_intro
Important Notice:
Run the VESC®-Tool software.
Vesc-Tool_ISW_connect
Vesc-Tool_ISW_welcome
Vesc-Tool_ISW_load default
Vesc-Tool_ISW_Set ID Master
Vesc-Tool_ISW_select ppm
Vesc-Tool_ISW_mapping_01
Vesc-Tool_ISW_mapping_02
Vesc-Tool_ISW_mapping_03
Vesc-Tool_ISW_mapping_04
Vesc-Tool_ISW_mapping_05
Vesc-Tool_ISW_mapping_06
Vesc-Tool_ISW_select slave
Comments
Godrej MSR City is a Mediterranean-themed, new-age Apartment project by Godrej Properties located in Shettigere, Devanahalli, Bangalore 562110. The total size of the project is 62 acres. There are 39 towers hosting 4000 luxury apartments. The project has 2 phases and offers 2, 3, and 4 BHK units in sizes of 1186 sq ft to 1876 sq ft. The prices start at INR 1.18 Crores.
Birla Evara is an upscale residential project situated near Sarjapur Road, Bangalore, offering a refined blend of luxury and functionality. Developed by Birla Estates, it features elegant 2, 3, and 4 BHK apartments designed for modern living. The project boasts premium amenities including a clubhouse, swimming pool, fitness center, landscaped gardens, and dedicated play areas. Its strategic location ensures excellent connectivity to IT hubs, top educational institutions, and healthcare facilities. With its thoughtful design, sustainable features, and serene surroundings, Birla Evara provides residents with a harmonious lifestyle that blends urban accessibility with tranquil comfort.
Godrej MSR City is an upcoming premium residential township located in Shettigere, Devanahalli, North Bengaluru. Developed by the renowned Godrej Properties, the project offers modern 2, 3, and 4 BHK homes designed for comfort and luxury. Its strategic location near Kempegowda International Airport and major highways ensures excellent connectivity to the city’s IT and business hubs. With lush landscapes, open green spaces, and world-class amenities like a clubhouse, swimming pool, and fitness center, Godrej MSR City promises a lifestyle of convenience and serenity. It’s a perfect blend of nature and modern living in one of Bengaluru’s fastest-growing zones.
https://www.godrejmsrcity.org.in/
Nambiar District 25 is a premium plotted development project located off Sarjapur Road at Muthanallur Cross in East Bangalore. This thoughtfully planned community offers well-designed plots surrounded by greenery, ensuring a peaceful yet connected lifestyle. Developed by Nambiar Builders, the project combines modern infrastructure with natural serenity, making it ideal for residential investment. With easy access to IT hubs like Electronic City and Whitefield, as well as schools, hospitals, and shopping centers, it offers both convenience and growth potential. Nambiar District 25 promises a secure, well-equipped environment with amenities that cater to modern living in Bangalore’s fast-developing corridor.https://www.nambiardistricts25.info/
Birla Evara is a premium residential development by Birla Estates located in the serene neighborhood of RR Nagar, Bangalore. This thoughtfully crafted project offers spacious 2, 3, and 4 BHK homes designed with elegance, functionality, and modern aesthetics. Surrounded by greenery and open spaces, Birla Evara emphasizes a lifestyle of wellness and tranquility. With world-class amenities including a clubhouse, gym, swimming pool, landscaped gardens, and children’s play areas, it caters to families seeking comfort and sophistication. Excellent connectivity to major schools, IT hubs, and hospitals makes it an ideal choice for urban dwellers looking for quality living in a peaceful environment.
Godrej MSR City is a premium residential project located in Yelahanka, North Bangalore. Spread across a vast expanse, it offers well-designed 2, 3, and 4 BHK apartments that blend comfort with modern aesthetics. The township features lush greenery, open spaces, and a host of world-class amenities including a swimming pool, gym, clubhouse, jogging tracks, and children’s play areas. Strategically positioned with easy access to Kempegowda International Airport, major IT hubs, schools, and hospitals, Godrej MSR City ensures seamless connectivity. It’s an ideal choice for families seeking a peaceful yet well-connected lifestyle amidst nature and urban conveniences.
Nambiar District is a thoughtfully developed township in Bangalore, offering a harmonious blend of urban comfort and natural beauty. Spread across a vast expanse, the district is designed with wide tree-lined roads, landscaped gardens, and modern infrastructure. It features premium plots, villas, and apartments, all built to deliver a luxurious yet sustainable lifestyle. With proximity to major IT corridors, reputed schools, and healthcare centers, it ensures convenience for daily living. The project emphasizes eco-friendly practices and open green spaces, making it a preferred choice for families and professionals seeking a peaceful yet connected life in a fast-growing city.
godrejtiaarra's picture
Godrej Tiara is an elegant residential development in Hinjewadi, Pune, crafted to offer a luxurious and serene living experience. Featuring well-planned 2, 3, and 4 BHK apartments, the project is designed with contemporary architecture and premium finishes. Its strategic location ensures excellent connectivity to IT parks, schools, and major highways. Backed by the legacy of Godrej Properties, Tiara delivers a lifestyle of comfort, class, and convenience.
Visit : https://www.godrejstiara.info/
birlaojassvvi's picture
Birla Ojasvi by Birla Estates is a luxurious residential township in Rajarajeshwari Nagar, Bangalore, offering premium 1, 2, 3 BHK apartments and 4 BHK row houses. Spanning 10+ acres with 80% open space, the project blends smart living with modern amenities. Its strategic location near NICE Road ensures seamless connectivity across the city.
Visit: https://www.birlaojasvi.net.in/
Twitter: https://x.com/birlaojassvvi
YouTube: https://www.youtube.com/@birlaojassvvi
Birla Ojasvi is a premium residential project by Birla Estates located in Rajarajeshwari Nagar, Bangalore. Spread over 10+ acres, it offers spacious 1, 2, 3 BHK apartments and 4 BHK row houses with world-class amenities.
prestigesttaar's picture
Prestige Southern Star is a landmark residential project by Prestige Group, located on Begur Road, Bangalore. It features meticulously crafted apartments with modern designs, lush landscapes, and premium amenities. Perfectly positioned for easy access to IT hubs, schools, and shopping centers, it offers an ideal urban lifestyle.
Website: https://www.prestigesouthernstar.live/
Twitter: https://x.com/prestigesttaar
YouTube: https://www.youtube.com/@prestigesttaar
Prestige Southern Star is an elegant residential enclave on Begur Road, Bangalore, crafted by the renowned Prestige Group.
birlaevvaam's picture
Birla Evam is an upscale residential project by Birla Estates, located in the fast-growing Hadapsar Annexe, Pune. It features stylish 1, 2 & 3 BHK apartments with modern amenities and serene green surroundings. The project offers excellent connectivity to business hubs, schools, and highways. Birla Evam is where elegance meets everyday convenience.
Website: https://www.birlaevampune.net.in/
Twitter: https://x.com/birlaevvaam
YouTube: https://www.youtube.com/@birlaevvaam
Birla Evam Pune by Birla Estates is a thoughtfully designed township in Hadapsar Annexe, offering elegant 1, 2 & 3 BHK homes.
TD777 Game is a real-earning online casino and card game that offers players a chance to win real money while enjoying a fun and interactive experience.
td777
I completely agree with the points shared here. Crafting a high-quality dissertation requires extensive research, critical analysis, and precise formatting, which can be overwhelming for many students. That’s why professional dissertation writing services can be a valuable resource—they not only help maintain academic standards but also guide students in presenting their ideas effectively while saving time and reducing stress.
Godrej Properties is building high-end homes in North Bangalore's Shettigere neighborhood. It's called Godrej MSR City. On 62 acres, the area is being built up in three stages. Phase 1 has luxury 2 and 3 BHK homes that are spread out over 19 acres and range in size from 1186 to 1876 square feet. It has five very fancy clubhouses that cover more than 1.5 lakh square feet of green land.
Yo, guys! If you're looking for an online casino with a buzz,
Black Diamons Casino AU is a must-have. I love everything about it: the selection of games, the fast payouts, and the welcome bonuses. Honestly, I didn't expect such an atmosphere; it's like you're really sitting in a casino. So I definitely recommend it—you won't be bored!
Godrej Regal Pavilion is a futuristic, ultra-luxury Royal Nawaab themed apartment project by Godrej Properties, strategically located in Gaganpahad, opposite McDonald's, Rajendra Nagar, South Hyderabad. The total area of this landmark project is 13 acres. It includes 9 towers hosting 2000 units of premium 2, 3, 3.5, and 4BHK apartments. The floor sizes of apartments range between 1300 and 2900 sq ft. The prices start at Rs. 1.10 Crores.
My family was visiting Dawson Creek for a reunion, and I needed ideas for group activities. Looked for something exciting to do together that wasn’t just sightseeing. Found Chances Dawson Creek, a Canadian-based site with everything from game options to dining suggestions. It’s packed with details on slots, live events, and bonuses like extra credits for first-timers. The Canada focus made it perfect for our trip. Booked a spot for us, and everyone had a great time.
I follow European football, especially Ligue 1, and needed a platform to add some excitement to the games. That’s how I came across betjili. The website has many different options for betting, plus promotions that include deposit bonus and free spins linked to popular sports. Bangladesh users also get the benefit of local methods and fair odds. I enjoyed it because it keeps me connected to matches with extra thrill.
This is incredibly helpful! I remember struggling with CAN-Bus configuration a while back and accidentally frying a VESC because I didn't realize the importance of isolating the 5V and GND. It was a costly mistake! Following these steps meticulously would have saved me a lot of grief. If you're looking for a way to visualize the potential damage of messing things up, try playing Solar Smash. It's oddly satisfying (and educational in a weird way!).
This is a great tutorial! Setting up multiple VESC's via CAN bus can definitely be tricky. I always appreciate clear instructions like these, especially for beginners getting into the VESC ecosystem. Finding the right settings for "Current No Reverse with Brake" mode is key for a responsive and safe ride. It's also super important to double-check you've got the latest VESC-Tool. Speaking of tools, I wonder if there's a future update that includes a diagnostic function like the one in the old Sprunki app – something that can really help troubleshoot CAN bus issues.
Quick Moderate Expert photo and video moderation & face recognition. Ensure content safety & compliance. Explore our services today.
Ensure a safe online environment with our advanced solutions for detecting sensitive content. Our effective moderation tools protect users and communities by identifying and managing inappropriate materials seamlessly. Discover how we enhance online safety and maintain brand integrity today!
Photo And Video Moderation & Face Recognition
Mcdvoice is an official site where valuable customer insights from the Survey will help restaurant like McDonalds to understand & satisfy customer needs and behaviour. These customer insights will be taken into consideration.  However successful restaurants run on understanding their customer satisfaction and providing high quality services to serve them better.
<a href="https://mcdtalks.com.co/">https://mcdtalks.com.co/</a>
Compared to traditional lighting solutions, White Screen offer numerous advantages: lower energy usage, longer operational life, reduced maintenance, and better light quality. Recognizing this demand early, White Screen Vip has positioned “White Screen” as a trusted partner in providing high-performance that meet modern expectations without compromising affordability or aesthetics. Many of the light sources that emit white light, but our tool has simple to use, uniform lighting distribution with a pure white color (#FFFFFF).
https://whitescreen.tools/
USPS tracking gives you a detailed view of your USPS package's journey, from label creation to delivery. Once a package enters the USPS network, you can get real time updates about your package.
After a day exploring Edinburgh’s castle, I craved a cozy indoor thrill. Looked for a UK-friendly site with charm. Found Mega Casino, pure UK class. Tons of slots, live blackjack, and a fast sign-up. Safe with SSL, takes GBP via Visa. Daily promos like extra spins are lush. Mobile’s smooth. By the way, support’s fast. Made my winter nights a proper laugh.
gU
gU
gU
gU
gU
gU
