Help Needed: Sending Individual Throttle Signals to Two Motors Over Bluetooth Using VESC
exenko
Hi everyone,
I'm working on a project that requires sending separate throttle signals to two different motors via Bluetooth. I need full bidirectional control of each motor's throttle independently to enable tank-style turning (where motors can rotate in opposite directions). I'm using the MakerX MBoards DV4S ESC with a Bluetooth module.
My current setup:
  • Successfully tested sending PPM signals from a Raspberry Pi directly to each ESC
  • Now trying to:
    1. Send commands over Bluetooth
    2. Separate the commands
    3. Send appropriate commands to each motor over the CAN bus
From my research, forum posts from about a year ago suggest this isn't possible without custom Lisp/QML programming. Has anyone found a solution since then, or can point me in the right direction?
Link to VESC
Any help or guidance would be greatly appreciated!
Foujiwara
You can contrôle the rotation by "Remote" via Vesctool on phone/computer by bluetooth so it's probably possible, but not easy and not with basic command, you need to emulate the exchange with the Vesctool maybe
but i don't know more, i understand anything about code
