throttle responce
TONY61
throttle responce
hope someone can help.
im setting up a vesk 60100hp on a bosch gen4 mid motor (No sensors. driuver board removed)
The motor detection works fine , as does the throttle detection (chinese ebike hall sensor type)
the throttle is mapping at 2..5v max input.
however the motor starts at approx 15% and is full speed at 20% .
its practically an on off switch, although tere is a ramp if your really carefull rolling on.
this is the second vesk ive tried and both reacted the same.
Any Ideas?
regards
Tony
electricfox
electricfox's picture
Last seen: 10 hours 45 min ago
Please dont post this everywhere. You are not alone on this planet.
