2. Motor Setup Wizard
Submitted by frank on Tue, 2017-10-03 19:49
In this tutorial we will configure a genuine VESC® motor controller in combination with a BLDC motor.
We will run the motor in FOC mode and we will make use of Hall sensors.
Vesc-Tool_MSM_intro
Vesc-Tool_MSW_wiring
Connect your VESC® to your computer using a mini/micro USB cable.
Run the VESC®-Tool software.
Vesc-Tool_MSW_connect
Vesc-Tool_MSW_start
Vesc-Tool_MSW_default
VESC-Tool MSW_choose FOC
Now we get the following options:
FOC = Field-Oriented Control
Advanced control mode (sinusoidal, silent, more efficient,
better motor sensor operation).
May cause damage to 3rd party hardware!
BLDC = Trapezoidal Control
More simple control mode (block commutation), noisier, hall-sensor operation
less accurate at this stage. Safer for operation of 3rd party hardware.
DC = Only for DC motors. Use phase wire A and C only!
Vesc-Tool_FW_current limits warning
The following explanations will help you to configure your current limits correctly:
Motor Current Max: The maximum current your motor can handle continuously (Ampere). Please refer to the motor specifications of your motor. You may use lower values to de-power your setup.
Our motor can handle 50A, but we will only set it to 30A to get started. You can boost your settings once you feel comfortable. A safe approach towards higher values is highly recommended (e.g. start with 15A only).
Hint: This value can be greater than the Battery Current Max value, resulting in a higher motor power output at part throttle. At max throttle the Battery Current Max is the limiting value if set lower than Motor Current Max.
Motor Current Max Brake: The maximum current output you allow your motor to produce when operated as a generator. Electric vehicles may use the motor as a brake, generating energy when slowing down the vehicle. The energy produced will be stored in the battery. In this tutorial we will set the value to -25A to get started. The value should not be higher than the max. continuous current specification of the motor.
Hint: Higher values will result in stronger brakes if the Battery Current Max Regen settings allows the storage of the current generated.
Battery Current Max: The maximum continuous current your battery is rated for. Please refer to your battery specifications for safe settings. LiPo-pack batteries are usually C-rated. A 5800mAh, 25C rated battery can handle 5.8A x 25=145A max. Manufacturers often overrate the batteries and cutting the value in half is recommend. We will use 72A max for safety reasons.
Hint: Since our Motor Current Max is set to 30A, we could use 30A for the battery as well.
Technically there is no reason to use a higher value than the Motor Current Max.
Battery Current Max Regen: The maximum current you allow the VESC to push towards your battery or battery management system (if incorporated in your system) when braking. This value should not exceed the maximum charge current rating of your battery or capability of your battery management system. Our battery is 5C rated for charging. We use a 5800mAh battery.
5.8A x 5 = 29A max. charge current.  Again: Better be pessimistic with those values! We will set it to -20A.
Hint: Since this value is lower than the Motor Current Max Brake (-25A), the firmware will limit the ampflow towards the Battery to -20A, regardless of the higher value we specified for Motor Current Max Brake (-25A). In consequence our maximum motor brake force is limited by the lower Battery Current Max Regen value.
Vesc-Tool_MSW_current limits set
Vesc-Tool_MSW_battery cutoff_warning
Now we will configure your battery cutoff voltage.
If you discharge your battery below a certain voltage, it will get damaged permanently. LiPo packs or Lithium ion Batteries usualy operate between 4.2V and 3.1V per cell. Do not allow your system to discharge them beyond 3.1V per cell! For this reason the VESC will measure your battery voltage and will start to softly cutoff the power at 3.4V per cell (Battery Votage Cutoff Start) and it will perform a hard cutoff at 3.1V per cell (Battery Votage Cutoff End).
You can also set custom values if your cells have different ratings.
Battery Voltage Cutoff End = number of cells in series x minimum cell voltage
VESC-Tool MSW_battery cutoff_set values
Next step is the choice of motor sensors
Sensors help the VESC to know the rotor position in refenrence to the copper coils. This way the motor can perform a relatively smooth startup from 0 RPM. If your motor features sensors you should make use of them. At higher RPM, the VESC will use back EMFs to calculate the rotor position. The RPM for switching to back EMF operation can be defined later.
No sensors: without motor sensors the motor needs to turn a bit, so the VESC can calculate the rotor position from the back EMF current flow that the magnets will induce into the copper coils when they rotate around the  the motor stator. Startup from 0 RPM is possible but a bit shaky.
Hall sensors: A transducer that varies its output voltage in response to a magnetic field. Usually a set of three sensors are acurately positioned inside or outside the motor to roughly determin the position of the rotor.
Commonly used, not very precise, good enough to guarnatee a smooth startup of a vehicle from standstill.
AS5047 Encoder: This is a chip sensing the magnetic field of a diametrally magnetized magnet, attached to the motor shaft. The precision is very high (14 bit) and allows very accurate determination of the rotor position.
ABI: Output signal of an incremental rotary encoder (mechanical, optical or magnetic).
Our motor has Hall sensors, so we will choose Hall sensor operation.
Vesc-Tool_MSW_select sensors
Next step is to measure your motor parameters
For the best possible result, do the detection without attached drive train, propellers etc.
Every single motor is unique and the VESC needs to know certain parameters to run the motor. The VESC needs to know the motor resistance, electrical inductance and flux linkage (λ). From these basic values other values can be calculated that are essential for the motor operation. So that‘s what we will do now.
Step 1:measure RL
The motor will make a loud humming noise
Step 2:measure λ
The motor will spin up. Make sure to disassemble propellers or lift up your vehicle from the ground or take any preparations necessary to allow your motor to spin up freely.
Step 3:Apply values
Vesc-Tool_MSW_motor parameter_01
Vesc-Tool_MSW_motor parameter_02
Vesc-Tool_MSW_motor parameter_03
Vesc-Tool_MSW_motor parameter_04
Vesc-Tool_MSW_motor parameter_05
Vesc-Tool_MSW_sensor calibration_01
Make sure that your motor can rotate freely, since the motor will start to turn slowly now.
Vesc-Tool_MSW_sensor calibration_02
Vesc-Tool_MSW_sensor calibration_03
Vesc-Tool_MSW_finish
Congratulations, you have finished the Motor Setup Wizard.
Please continue with the Input Setup Wizard.
Comments
The Love language test is a personal inventory that allows you to measure and understand how you like to give and receive love in romantic relationships. It measures a concept similar to the five love languages, which was developed in the 1990's by psychologist and marriage counselor Dr. Gary Chapman, but with some key improvements based on Truity's empirical research.
MetaMask is a secure Ethereum wallet and browser extension for Chrome, enabling users to manage crypto assets and interact with decentralized applications (dApps). It provides an intuitive interface for storing, sending, and receiving Ethereum and ERC-20 tokens, ensuring seamless and secure blockchain transactions directly from your browser.
MetaMask Chrome Extension | MetaMask Chrome Extension
Thank you for taking the time to write and share these great cooking tips. I have learned a lot of new things. Play game bou's revenge free.
Zerion Wallet Extension empowers you to manage your crypto portfolio with ease. Access DeFi, NFTs, and multiple blockchains in one secure, user-friendly interface. Enjoy seamless transactions, real-time asset tracking, and advanced features to optimize your crypto experience. Your gateway to the decentralized web. Zerion Wallet Extension .
Phantom Wallet Extension offers a simple, secure way to manage your Solana and Ethereum assets. Easily swap tokens, collect NFTs, and explore Web3 with a user-friendly interface. Experience fast transactions, top-notch security, and seamless integration across multiple devices. Unlock the full potential of the decentralized world. Phantom Extension.
I appreciate you sharing this blog. For individuals who are looking for pertinent information, this is a huge aid.
slope
This is one of the best articles I have ever read on this blog. Thank you for sharing very interesting information.
Wordle
Looking to enhance your cryptocurrency experience? Get started with Wallet Connect download for seamless integration. Discover more about WalletConnect and unlock the full potential of the WalletConnect App today!
MetaMask Extension is a leading tool in the world of cryptocurrency and decentralized finance (DeFi). This browser extension, available for Chrome, Firefox, Brave, and Edge, acts as a bridge between traditional web browsers and the Ethereum blockchain. By using MetaMask, users gain secure access to their Ethereum wallet, enabling them to manage assets, interact with decentralized applications (dApps), and execute transactions seamlessly. MetaMask Extension | MetaMask Extension
MetaMask is a cryptocurrency wallet which can be used on Chrome, Firefox and Brave browsers. It's also a browser extension. This means that it works like a bridge between normal browsers and the Ethereum blockchain. The MetaMask extension can be used for storing keys for Ether and ERC-20 tokens on three different web browsers. It also allows users to browse the Ethereum blockchain from a standard browser. MetaMask Extension | MetaMask Extension | MetaMask Extension | MetaMask Extension | MetaMask Extension | MetaMask Extension | MetaMask Extension | MetaMask Extension | MetaMask Extension | MetaMask Extension | MetaMask Extension | MetaMask Extension | MetaMask Extension | MetaMask Extension
Secure your Crypto.com account with easy login access. Manage your cryptocurrencies, track investments, and explore the world of DeFi in one secure platform. Login seamlessly with advanced security features and stay connected to your digital assets anytime, anywhere. Start your crypto journey with Crypto.com today. Crypto.com Log in | Crypto.com Log in
Secure your Crypto.com account with easy login access. Manage your cryptocurrencies, track investments, and explore the world of DeFi in one secure platform. Login seamlessly with advanced security features and stay connected to your digital assets anytime, anywhere. Start your crypto journey with Crypto.com today. Crypto.com Login | Crypto.com Login | Crypto.com Login | Crypto.com Login | Crypto.com Login | Crypto.com Login | Crypto.com Login | Crypto.com Login | Crypto.com Login | Crypto.com Login | Crypto.com Login | Crypto.com Login | Crypto.com Login | Crypto.com Login | Crypto.com Login
Access your Bitstamp Pro Login account for advanced trading features, real-time market data, and secure transactions. Log in to manage your portfolio, execute trades, and monitor the cryptocurrency market with professional tools and insights.
Bitstamp Pro offers a user-friendly interface designed for both experienced traders and beginners. Ensure your account security with two-factor authentication and enjoy a seamless trading experience on one of the world's most trusted cryptocurrency exchanges. Start trading now with confidence on Bitstamp Pro.
Bitstamp Pro Login | Bitstamp Pro Login
Coin98 Wallet is a multi-chain decentralized finance (DeFi) wallet that allows users to manage, store, swap, and stake a wide range of cryptocurrencies across various blockchains. Developed by Coin98 Finance, the wallet is designed to support multiple blockchains, including Ethereum, Binance Smart Chain, Solana, and many others, making it a versatile tool for DeFi users. Coin98 Wallet
The TronLink Wallet extension is a popular browser extension used to manage TRON (TRX) and TRON-based assets. It allows users to interact with TRON's blockchain directly from their web browsers, making it easy to manage TRX, TRC-10, and TRC-20 tokens, interact with decentralized applications (dApps), and sign transactions securely. Tronlink Wallet Extension
""Clicker" games like "banana game" are played. To get to the fruit, you must click on the banana. It's easy! With more bananas, you can purchase more items from the banana shop. This will enable you to obtain additional bananas.
Ingin meraih maxwin? Kaya303 punya solusinya! Link gacor hari ini siap memberikan Anda kemenangan besar yang dijamin. Klik sekarang dan buktikan sendiri!
Infinity Wallet Extension offers a seamless, secure way to manage your digital assets. With support for multiple cryptocurrencies, users can easily store, send, and receive crypto directly from their browser. Experience unmatched convenience, enhanced privacy, and real-time tracking of your portfolio, all in one intuitive extension. Infinity Wallet Extension | Blade Wallet Extension
Discover Phantom Wallet Extension, the ultimate solution for managing your crypto assets effortlessly. This secure and user-friendly browser extension allows you to store, send, and receive cryptocurrencies with ease. Enjoy seamless integration with decentralized applications (dApps) on the Solana blockchain, enabling smooth transactions and enhanced features. With Phantom Wallet, you can track your portfolio, access DeFi platforms, and explore NFTs—all in one place. Elevate your crypto experience today! Phantom Wallet Extension | Phantom Wallet Extension
There are various dissertation internet websites on the net when you attain definitely reported with your web page.
block blast game
That's internet marketing special deals plans as a way to important consider before ad. Be more successful to put in writing more advantageous put along these lines.
Popcorn game online
Whenever I have free time, I visit blogs to find useful information. Today Fnaf, I found your blog with the help of Google. Trust me; I find this to be one of the most informative blogs. retro games
Writing a nursing research essay involves several key steps to ensure a comprehensive and well-structured paper. Start by selecting a relevant topic that interests you and is significant to the nursing field. Conduct thorough research using credible sources such as academic journals, books, and reputable websites to gather information.
Next, create a detailed outline to organize your thoughts and structure your essay logically. Your introduction should provide background on the topic and state your thesis clearly. In the body, present your findings, supporting each point with evidence and analysis. Finally, conclude by summarizing your key arguments and discussing the implications of your research.
If you need additional support, visit our website for nursing essay help. We offer resources and professional guidance to assist you in crafting a high-quality nursing research essay that meets academic standards.
Hey everyone!
I’ve been playing Connection NYT for a while now and wanted to share some tips that have really helped me improve my game play. I’d love to hear your strategies too!
My Top Tips:
  1. Start with the Obvious: Always look for the most straightforward connections first. It often helps to clear out some options early.
  2. Use Process of Elimination: If you’re stuck, eliminate the connections that don’t fit. This can help you see potential pairs more clearly.
  3. Group Similar Items: Try to categorize words into themes. This can help in visualizing possible connections.
  4. Practice Makes Perfect: The more you play, the better you’ll get at spotting patterns. Don’t hesitate to replay puzzles!
  5. Stay Patient: Sometimes, taking a break can give you a fresh perspective when you return.
What are your go-to strategies? Let’s help each other out!
Happy gaming!
I just discovered Connections NYT, and I’m hooked!
Trezor hardware wallets are physical devices that allow users to manage their digital assets securely. When you receive your Trezor, the first step is to visit Trezor.io/start, which will guide you through the process of setting up and securing your wallet. trezor.io/start
The Binance Wallet Extension is a secure and user-friendly browser extension designed to simplify the management of cryptocurrencies directly from your web browser. It enables users to store, manage, and transfer cryptocurrencies, as well as interact with decentralized applications (dApps) on various blockchain networks. As an extension of the Binance ecosystem, it integrates seamlessly with the Binance exchange, making it an ideal tool for traders and crypto enthusiasts who seek convenience and security. Binance Wallet Extension
There are particular dissertation web-sites with websites in making guarantee apparently taken into your website.
block blast online
Popcorn game
