Cheap Focer Troubleshoot DRV
Niklas Probst
Hi Vesc community,
I assembled the cheap focer myself, in an industrial environment. On first startup,
I ran the motor configuration wizard. The attached brushless motor twitched a little bit (about 1 sec),
then stopped and the red light flashed 3 times. Untila a few seconds it tries again, but the motor won't
rotate correctly.
When I type fault in console, I get the DRV Fault.
How can I measure through the vesc, to find the fault?
And when do I have to bridge on/off pins on vesc?
(I limited the current to 1 Amp with 11 Volts when testing and it draws about 80mA in idle and
I hear a weired high frequency noise coming from the vesc)
(I have an oscilloscope, multimeter smd reflow station and some electronical knowledge)
Thank's in advance for every answer, I'm stuck on this problem for a few days.
Niklas
Niklas Probst
Okay, now I resoldered every Pin from the DRV8301DCAR. Did Motor Detection wizard, the motor again twitches a little bit for about a second, but doesn't spin. The red light flashes and I get an error -11.
Faults in console outputs: FAULT_CODE_NONE
Any Ideas, what this means?
