Reverse button configuration
ElectroToshka
Last seen: 11 months 22 hours ago
Hello Guys,
could you please help me.
I have a Seekerboard.
It has esc controller
105L 500 Вт с двойной крестовиной резиновые концентратор для погружающийся + ESC6.1 Dual Drive ESC 100A 8-60V 3 S-12 S Батарея для 4-х колесный электрический
Remote PPM had 3 modes of speed and double pressing power button did a direction switch of the motors
accidentially i've broken Factory settings in Vesc application and now i cannot restore them.
I cannot find how to restore 3 speed modes on ppm and reverse mode by double taping power button.
Could you please advise how can i configure it back in VESC app?
Thank you in advance
ElectroToshka
You need to ask the manufacturer for support. It is a feature of the remote I guess. In VESC-Tool you can set reverse via the PPM App. Either choose Current Hyst. Reverse With Brake or Current Smart Reverse. Smart reverse engages when you hold the brakes after stand still. Hyst. Reverse engages when you brake again, after stand still. So back to neutral and then re-engage brakes.
ElectroToshka
What to do if manufacturer's site of skateboard is closed and doesn't work?
On lesdiy.com i also cannot find any pages or info about this controller
Well then just forget this remote and controller and use something with product support.
