| Parameters |
| tyre diameter |
mm |
tyre diameter (e.g. Trampa stickies 83x52mm) |
| motor pulley |
teeth's |
teeth on motor side |
| slave wheel |
teeth's |
teeth on wheel side |
| motor value |
Motor selection |
| battery choise calculator |
| Manufactur |
Serial Cells
(S) |
| Palrallel cells (P) |
| V |
| V |
| V |
| A(Peak) |
| Ah |
| Wh |
type of battery, cell count, maximum voltage, peak current |
| drive power |
throttle |
| adversities |
| weight setup |
kg |
weight of rider + board |
| pp hill climb |
ascent in %
Baldwin Street = 35% (world's steepest street!) |
| Results |
| speed |
Km/h |
speed calculated |
| power |
W |
power usage from battery |
| current |
A |
current limited by Imax |
| drive duration |
minute |
ride time |
| distance |
Km |
ride distance |
additinal energy
for acceleration |
acceleration duration to reach Vmax
additional power needed for acceleration
additional current at acceleration phase |
| ADVANCED ⇓⇓⇓ |
| Imax |
A |
maximum current limited by: battery, balancer, ESC limit, motor limits |
| Ibase |
A |
current used for electronics |
n
coeficient of performance |
coefficient of performance including motor, electrical system and mechanical losses |
| air resistance |
| p |
kg/m3 |
air density at 20°C |
| cw |
air resistance of a human at 45° angle towards direction of travel |
| surface |
m² |
surface of a human |
| frictional resistance |
| cr |
frictional resistance (wheel on concrete 0.01) use higher value for other surfaces like sand (0.5) etc.
| Calculation |
F means force; |
| F flow resistance |
N |
resistance air |
| F sloping |
N |
F climbing |
| F roll resitance |
N |
force wheels |
| F overall |
N |
summ of all forces |
| P |
W |
motor power needed |
| RPM Motor |
RPM |
RPM motor |
| RPM wheel |
RPM |
RPM wheel |
| gear ratio |
1:x |
gear ratio |
| torque |
Nm |
torque motor |
| torque |
Nm |
torque wheel |
| losses and voltage sag |
