Hi All: My project involves commanding certain torques and speeds to a motor via VESC 6 EDU from a Rasberry Pi. For best reliability, should I use CAN or UART or something else to interface with the VESC? Should I use a specific BLDC frmware version for reliability? The motor is low speed/high torque with Hall sensors: https://www.aliexpress.us/item/3256803118723106.html
CAN is the most robust choice.
NextGen FOC High voltage 144v/34s, 30kw (https://vesc-project.com/node/1477)
