Configuring VESC for brushed motors
patrick.manson....
Last seen: 2 weeks 2 days ago
I have a VESC 6 EDU from here: https://trampaboards.com/vesc-six-education--with-imu-p-34332.html
I am trying to get it to run a brushed DC motor. I reset the configuration to default, set motor type to DC, uploaded the motor configuration, and tried to run the motor through vesc tool. The duty cycle as reported by the VESC was 95%, however the motor did not run. I measured voltage across all pairs of of motor output and each pole to ground, and they were all off. I have the motor connected to A and C, and confirmed that it works with a benchtop power supply. If I set it to FOC the motor wines, and I have used the VESC to control brushless motors.
Any ideas on how to configure it to run? Or is there a different issue here?
Patrick
