what if HIGHT voltage battery to the MakerX GO-FOC DV6/PRO ESC (VESC6) ?
Argazmo
Argazmo's picture
I find that it is possible to install in my "FAT BOARD" project of electric longboard 17S3P LiFePO4 (3.3v) 26650 a123 battery pack. (Before I ordered components to 16S). I find nice 20A 58.8v charger for 48v battery pack (also there is 15A and 10A). I have 2 pcs MakerX GO-FOC D75, but it is 113mm wide, I need to use DV6 pro (https://www.makerx-tech.com/collections/x-esc/products/go-foc-dv6-dual-1...), because it is 106mm, yes, critical 7mm =(
And my question is: If it is possible to use MakerX GO-FOC DV6 pro with 58.8v??
In the description it is "Voltage: 8-60V (3-12sLIPO)"
12S LiPo mean that it will be under 51v (12x4.25v)
But I will use 17S LiFePO4, what will be charged to 3.46v (58.8/17) and will be ~3.4v (<58v) after some hours after charging without load. And with load it will be ~2.7v (46v) if 60A per cell.
So, I know that this ESC based on VESC open project, and maybe someone know, if all components of it will work with 59v?
