PAS: constant torque control
afzalm
( Though a pull request [1] for implementing this feature has been sent, this post is being made as 'CONTRIBUTING' document mentions discussing changes in the forum )
Current pedal assist provides cadence control. With such a control scheme, riding uphill on a gearless e-bicycle requires rider to put lot of effort during uphill (changing to low gear on geared bicycle with cadence type control makes uphill ride easier). Having Constant Torque whenever rider pedals would make riding easier uphill (as well as start) on gearless bicycle. Some of the popular (not high end) e-bicycles available locally seems to have this kind of control based on the riding experience. This corresponds to 'Basic PAS, constant throttle' of 'PAS Control Schemes' [2], with the difference that throttle setting in that article corresponds to speed, while here torque. The implementation is simple as well.
See pull request [1] for more details
[1] https://github.com/vedderb/bldc/pull/346
[2] https://ebikes.ca/learn/pedal-assist.html
TittyTwister
I would love to have something like that. I think that would be the perfect ebike. You just enter the desired torque and you paddle with it regardless of going uphill, downhill or flat. No mor need for switching assist levels. Let me know if something like that is available.
Ebike 1500W hub motor
