PPM with ADC
11 posts / 0 new
vufmihai
PPM with ADC
Hello
Any chance you can add PPM with ADC input in the future?
Or if a custom firmware can be made
i built a custom power wheels for my son an i want to have ADC input set and override it with PPM for safety purposes
if that is not possible, how can i save both configurations of ppm and adc and just jump between them by bluetooth or a pfisical button
now every time i want to change from ppm to adc or the other way around i have to do the input setup wizard evry time
Thank you
CTSchorsch
did you try to use the ble app to override the adc value from your son ? i think the ble (uart) has more priority
Regards
Georg
vufmihai
yes i tried but it dosent have enough range
and on ppm i can control the front disc brakes and the stearing
it woud be nice atleast if i can store the setup for ppm and adc and jump from them on bluetooth like the speed limit profiles
vufmihai
Nobody can help me?
Last seen: 2 days 15 hours ago
Currently you can only use one App at a time. Either ADC or PPM or UART.
vufmihai
I know what i ca use now
I will connect a servo motor to the throtle and brake to controll the car remotely
The other problem i have is that i dont know how to connect rhe reverse button when i use uart with adc i am using a flipsky 6.6 dual plus
vufmihai
I will connect a servo motor to the trothle and brake to control the car remotely
ems23
Last seen: 2 weeks 4 days ago
Hey @vufmihai,
I am doing the same thing! I want PPM to override ADC value.
(Controll my son's car via a remote I have from my FPV drone controller)
How did you end up solving this?
vufmihai
hello
i manage to solve this by using my receiver to control 2 servo motors
one servo has to steel wires connected to brake pedal and throttle pedal
when i press to accelerate it realeses the brake pedal and accelerates
and the other servo controles the reverse switch
in this way my son can drive the go cart and i can supervise with access to the brake if neded
i also have a steering servo
this is my sons go kart
still work in progress
https://www.youtube.com/watch?v=O7-Z1RSJmNI
i am stuck connecting the uart bluetoth. i cant make the reverse button work
getinthebag
I have done a similar thing to a little kids speed boat that can be controlled internally or externally via a remote.
The VESC is set up on a ppm input that is either directly fed from a remote control receiver, or emulated using an Arduino and potentiometers.
I've been used a third channel on the remote to flick between the two. This third channel goes into the same Arduino and if a certain ppm signal is detected (i.e 3rd channel activated) a 5v output triggers some logic gate ICS to switch between either the Arduino ppm or the RC ppm
With this is I have a fair bit of noise on the Arduino ppm at the moment because of the potentiometers, the VESC can filter out this noise fine but the servo jitters. My solution is to probably move to Hal sensors rather than potentiometers in the near future.
Hopefully this makes sense and can help somebody.
If anyone needs the Arduino code etc. I can pass it on.
k3ff
Last seen: 8 hours 22 min ago
So If I remove bluetooth I can use that port as ADC ?
speedlimits schpeeedlimicjtz
