VESC for IOS
keanusam
Last seen: 1 year 2 weeks ago
VESC for IOS
Hi, will there be a VESC app for IOS in the pipeline.
Last seen: 1 week 6 days ago
Yes, the countdown is on.
Chaos
Last seen: 1 year 3 weeks ago
Can't wait! :)
rtp
Last seen: 2 years 2 weeks ago
On the appstore now and can confirm it works, which is great..other than what seems to be a bug in selecting a directory for logging.
Cristof
I have been using VESC TOOL on my iPhone for some time to read the data from my FLIPSKY esc via a Bluetooth module of the same brand and change the CONTROL TYPE parameter in the CFG/PPM APP tab.
I did a false manipulation pressed the READ button instead of the WRITE button.
Since then, I can no longer use the application because I have a READ FIRMWARE VERSION window that opens whose message is:
COULD NOT READ FIRMWARE VERSION. MAKE SURE THAT THE SELECTED PORT REALLY BELONGS TO THE VESC.
Do you have a solution to solve this problem?
In addition, using a mac, I am looking for a compatible version of VESC TOOL.
Warmly
