Old only PCB VESC
Ştiube
Old only PCB VESC
Hi!
this VESC is the original one from vedder under the case? i want to use 2 of his vescs for a sumo mega robot, but the old boards are not available for purchase and i do not want to start building ones. can the case be removed and so under the case is that board?
thank you!
Last seen: 10 hours 17 min ago
VESC BronzeVESC FreeVESC GoldVESC OriginalVESC Silver
What do you want?  The VESC 6 PCB can be removed from the Housing, but you would need to make your own new housing to tit it too. The Housing is the heat sink.
Ştiube
so the pcb is not as the old one. that did not required any heatsink,  this is to big and heavy for my project.
