Half FSESC6.6 not working through can-bus
9 posts / 0 new
sergio
Hello guys. Im new here. I hope you can give me a push because im starting to frustrate myself haha.
I have the Dual Flipsky 6.6. It is single board that integrates two escs connected through can-bus- Im posting this problem here because i suspect that i has to do with the vesc-tool.
I know that both the escs work well because individually and connected to the usb, both are able to spin the motor in the motor setup wizard. The problem comes when i want to run both like im supposed to do for a electric board. The master esc works and responds to the ppm radio input. The orher one doesn`t move because it doesn`t recieve the can-bus comunication from the master.
Im aware that there is a swich to connect/disconnect the can-bus "cable" and i have also tried to make the can-bus comunication manully in the comunications tab but the tool launches an error message saying that the version does not support can-bus ??¿¿
I suspect that the problem is with the tool`s version (wich is the latest v1.19) so i tried 0.95 wich i know prompts you to make the can-bus setup in the input wizard but i can`t use 0.95 because the firmware in the escs is too new so it tells me to downgrade wich i can`t do neither!! The downgrade seems to work fine but then when it reboots it shows the same version xd
If someone can tell me something, even if it`s just a small clue i will be super thankfull!
d
Last seen: 1 year 3 weeks ago
I am having the exact same issue? Anyone?
beaubaby
HAve you had any luck? ive got the same problem
Thijs
Last seen: 2 weeks 3 days ago
Same problem over here... Hope someone finds the solution. I'm currently on version 2.06
JaesonLane
Same issue with one, anyone have a solution for this?
Jaeson Lane
marshalldog
Same problem
Adam9696
Guys, i have a solution! Few days ago one of my flipsky fesc6.6 mini broke up, The can not response, i was thinking that the switch wich is tuning on and off can comunication is bad so i check it in my another 6.6 mini, after move the switch this vesc lose can comunication too. Today i solder the pads of this switch and it solved the problem. There is link where i marked wich pins must be short. (two separate shorts, one at the top of the switch and one at the bottom.
https://www.dropbox.com/s/rqt908n9wp3u1qr/1612095381503.jpg?dl=0
Adam
Parad0x3
Last seen: 4 weeks 9 hours ago
Hello
I got the same problem. Do you mean both of pin in the square needs to be short together ?
bjorn westen
Last seen: 1 week 4 days ago
Hey all i had the same problem. Vesc tool 3.00 lets u connect can bus manually under the connection tab that worked for me. Just go to manually than select ur Fesc and than u connect can
drg
