Software TODO list
Submitted by benjamin on Tue, 2017-09-05 22:02
This is a TODO list for features in VESC Tool and in the VESC firmware. It will be updated on a regular basis.
Date Added Task Link Status Done in FW
2017-09-05 PPM reverse function with double tap. 1 Done 3.58
2017-09-05 Different throttle curves for forwards and reverse.   Done 3.28
2016-02-10 Speed ramping. 1 TODO
2017-08-01 Proper hall sensor support for BLDC   TODO
2017-09-01 Overcharge soft cutoff.   TODO
2017-09-05 NTC Beta factor configuration option. 1 Done 3.28
2017-09-05 Fix RT data timescale. 1 Done 3.28
2017-09-05 FW: Add board configuration file and set correct pin modes at boot.   Done 3.28
2017-09-06 cPPM APP with mixing 1 TODO
2017-10-14 Field weakening 1, 2 TODO
2017-10-17 Online parameter changes 1 Done 3.42
2017-10-26 Different temperature cutoffs for acceleration and brake   Done 3.30
2017-11-06 PID handbrake at full brake option when sensors are present. 1 TODO
2017-11-23 Proper torque-controlled brake from 0 speed. 1 Done 3.47
2018-03-06 Step/Dir app for CNC applications and similar. 1 TODO
2018-03-16 Support for pedal sensor in ADC app (legal requirement in some places). 1 TODO
2018-03-23 APP_ADC: Safe start after braking feature. 1 TODO
2019-07-05 Hall sensor and other hardware debugging support in VESC Tool 1 TODO
To see a list of all changes between the firmwares, have a look at the changelog.
Comments
Hi Benjamin,
According to the changelog, it seems that Github Firmware Source Code is still 3.33.
Can you upload the latest one, please?!
Bonjour avec vesc 6.4 quelles sont les valeurs maximales applicables au courant du moteur, au courant de la batterie et au courant maxi?
Si je veux 2 vesc dans ma configuration, devrais-je compter la valeur × 2 ou l'ampère reste le même et gauche 50/50?
Merci d'avance pour vos réponses.
it says i need the latest firmware so i can program my Dual board. i have NO PROBLEM donating money but i cant until someone shows or tells me how to do it.
Edward Gryglaszewski
These a quite good tips. I too have a meeting with my team’s
marketing assignment help I have been planning this trip for a while now because I was nervous that I may forget some important thing at the end time but I think your tips will help me in this. Thank you so much for these tips, I hope your meeting was successful!
Friday Night Funkin is not what you think when looking at the first images of the poster. It's literally the funniest witty music I've ever played.
And the surprise is that it also has a storyline, not flying in and entering like other music games. No matter what the next steps are, in the beginning, I gave it an A+ because of the difference.
The story of the game is divided into several weeks, representing the encounters and challenges of the godfather for you. Each week there will be 3 different difficulty levels. The harder it is, the faster your rhythmic coordination as well as your speed of grasping the notes should be.
If you want to play games for free, then come here lol beans there are many good and attractive games to help you relax and entertain in your spare time.
With a VESC®-based ESC, there are normally two primary version numbers. 1. Hardware Configuration  paper.io 2
<p>&lt;a href="https://usguncenter.com/product/beretta-1301/"rel="dofollow"&gt;beretta 1301 tactical gen 2&lt;/a&gt;<br />
&lt;a href="https://usguncenter.com/product/beretta-92-series-3rd-gen-inox-stainless... 92 threaded barrel stainless&lt;/a&gt;<br />
&lt;a href="https://usguncenter.com/product/beretta-92fs-compact/"rel="dofollow"&gt;... 92fs fusion&lt;/a&gt;<br />
&lt;a href="https://usguncenter.com/product/beretta-slide-fully-assembled-92fs-verte... vertec slide&lt;/a&gt;<br />
&lt;a href="https://usguncenter.com/product-tag/beretta-pico-rebate/"rel="dofollow"&... pico rebate&lt;/a&gt;<br />
&lt;a href="https://usguncenter.com/product/beretta-92fs-inox/"rel="dofollow"&gt;ber... 92fs inox for sale&lt;/a&gt;<br />
&lt;a href="https://usguncenter.com/product/beretta-92a1/"rel="dofollow"&gt;db334aab... />
&lt;a href="https://usguncenter.com/product/benelli-montefeltro/"rel="dofollow"&gt;b... montefeltro camo&lt;/a&gt;<br />
&lt;a href="http://usguncenter.com/product/beretta-bu9-nano/"rel="dofollow"&gt;beretta nano buds&lt;/a&gt;<br />
&lt;a href="https://usguncenter.com/product-tag/nano-9mm-carbine/"rel="dofollow"&gt;... 9mm carbine&lt;/a&gt;<br />
&lt;a href="https://usguncenter.com/product/beretta-px4-storm-45/"rel="dofollow"&gt;px4 storm sd type f&lt;/a&gt;<br />
&lt;a href="https://usguncenter.com/product/beretta-a300/"rel="dofollow"&gt;beretta a300&lt;/a&gt;<br />
&lt;a href="https://usguncenter.com/product-tag/manurhin-mr73-california/"rel="dofol... mr73 california&lt;/a&gt;<br />
&lt;a href="https://usguncenter.com/product-tag/beretta-92-fluted-barrel/"rel="dofol... 92 fluted barrel&lt;/a&gt;<br />
&lt;a href="http://usguncenter.com/product/beretta-m9a3/"rel="dofollow"&gt;beretta m1a3&lt;/a&gt;<br />
&lt;a href="https://usguncenter.com/product/beretta-nano-sniper-grey-frame/"rel="dof... nano white frame for sale&lt;/a&gt;<br />
&lt;a href="https://usguncenter.com/product-tag/stainless-beretta-92-barrel/"rel="do... 92 stainless steel barrel&lt;/a&gt;<br />
&lt;a href="https://usguncenter.com/product/beretta-92-threaded-barrel/"rel="dofollo... barrel for beretta 92fs&lt;/a&gt;<br />
&lt;a href="https://usguncenter.com/product/beretta-apx-magazine-9mm-17rds-packaged/... apx magazine 9mm 17rds&lt;/a&gt;<br />
&lt;a href="https://usguncenter.com/product/beretta-694/"rel="dofollow"&gt;beretta 694&lt;/a&gt;<br />
&lt;a href="https://usguncenter.com/product/beretta-m9a4-full-size/"rel="dofollow"&g... rmr&lt;/a&gt;<br />
&lt;a href="https://usguncenter.com/product/beretta-92-3rd-generation-barrel-9mm-sta... 92fs inox barrel&lt;/a&gt;<br />
&lt;a href="https://usguncenter.com/product/beretta-apx-threaded-barrel-9mm-bbl-125m... apx 9mm threaded barrel&lt;/a&gt;<br />
&lt;a href="https://usguncenter.com/product/beretta-conversion-kit-22lr-for-92-serie... conversion kit .22lr for 92 series&lt;/a&gt;<br />
&lt;a href="https://usguncenter.com/product/beretta-a400-xtreme-plus-kryptek-wraith/... xtreme plus kryptek wraith&lt;/a&gt;<br />
&lt;a href="https://usguncenter.com/product/beretta-apx-a1/"rel="dofollow"&gt;beretta apx a1&lt;/a&gt;<br />
&lt;a href="https://usguncenter.com/product/imr-4198-smokeless-gun-powder/"rel="dofo... />
&lt;a href="https://usguncenter.com/product/blackhorn-209-black-powder/"rel="dofollo... 209 powder academy sports&lt;/a&gt;<br />
&lt;a href="https://usguncenter.com/product/hodgdon-longshot-smokeless-gun-powder/"r... powder in stock&lt;/a&gt;<br />
&lt;a href="https://usguncenter.com/product/beretta-brx1/"rel="dofollow"&gt;BERETTA BRX1&lt;/a&gt;<br />
&lt;a href="https://usguncenter.com/product/imr-3031/"rel="dofollow"&gt;imr 3031 for sale&lt;/a&gt;<br />
&lt;a href="https://usguncenter.com/product/accurate-magpro/"rel="dofollow"&gt;accurate magpro&lt;/a&gt;<br />
&lt;a href="https://usguncenter.com/product/hodgdon-titewad/"rel="dofollow"&gt;hodgdon titewad&lt;/a&gt;<br />
&lt;a href="https://usguncenter.com/product/hodgdon-hp-38/"rel="dofollow"&gt;hp38 powder for sale&lt;/a&gt;<br />
&lt;a href="https://usguncenter.com/product/imr-enduron-4166/"rel="dofollow"&gt;imr 4166&lt;/a&gt;<br />
&lt;a href="https://usguncenter.com/product/vihtavuori-n350-smokeless-gun-powder/"re... powder&lt;/a&gt;<br />
&lt;a href="https://usguncenter.com/product/imr-4064/"rel="dofollow"&gt;imr 4064 for sale&lt;/a&gt;<br />
&lt;a href="https://usguncenter.com/product/hodgdon-trail-boss/"rel="dofollow"&gt;trail boss powder in stock&lt;/a&gt;<br />
&lt;a href="https://usguncenter.com/product/imr-7828-ssc/"rel="dofollow"&gt;imr 7828&lt;/a&gt;<br />
&lt;a href="https://usguncenter.com/product/ramshot-tac/"rel="dofollow"&gt;ramshot tac load data&lt;/a&gt;<br />
&lt;a href="https://usguncenter.com/product/imr-4227-smokeless-gun-powder/"rel="dofo... powder&lt;/a&gt;<br />
&lt;a href="https://usguncenter.com/product/hodgdon-h1000/"rel="dofollow"&gt;h1000 powder 8 lbs in stock&lt;/a&gt;<br />
&lt;a href="https://usguncenter.com/product/blackhorn-209-black-powder/"rel="dofollo... 209 Black Powder&lt;/a&gt;</p>
biggboss16cam's picture
The next season of Bigg Boss OTT is all set to be launched and now Kat
Kristian name has popped up as one of the celebrities approached for the
Bigg Boss 16 Full Episode
FR Legends MOD APK is the new emerging and trending drifting and racing game that has made people fall in love with it. The graphics, displays, sound, new maps, cars, and many other cool stuff make it worth playing the game.
FR Legends APK is the website where you can get apk file and the latest version of the game with everything you want like unlimited money, diamond, maps, cars, and more. Download the game today and enjoy the best experience you can ever have!
walter simon
Shadow Fight 2 is a role-playing fighting game published and developed by Cyprus-based Nekki. It is the second installment in the Shadow Fight series and was soft-launched on October 22, 2013. The full game was released worldwide on May 1, 2014, for both the Android and iOS operating systems.
https://shadowapkmod.com/
shadow fight 2
