1. Updating the Firmware
Submitted by frank on Tue, 2017-10-03 19:49
In this tutorial we will update the firmware on a genuine VESC® motor controller.
If you have 3rd party hardware, please find out the revision number (e.g. 4.12) prior to updating the firmware.
Wrong firmware will permanently damage your hardware!
VESC-Tool Firmware update_tutorial
Power up your VESC® motor controller and connect it to your computer using a USB cable.
Some cheap micro USB cables are designed for charging your
Run the VESC®-Tool software.
VESC-Tool_FW_outdated
Click on firmware in the left menu bar. This will bring you to the screen shown below.
Make sure to select the correct Hardware! Wrong firmware will instantly and permanently damage your hardware
when you try to operate it.
Vesc-Tool_FW finished
Vesc-Tool_FW_back home
Congratulations, you have successfully updated your firmware!
If you fail to update the firmware, your hardware probably has no bootloader installed. Please refer to the bootloader upload manual.
Please continue with the Motor Setup Wizard now.
